修改时间 07-20-2010 09:26 AM
我将C语言的一个程序写成DLL,但是结构point {float x;float y; float z},怎么实现,如果是用簇数组的话,怎么索引每个点的坐标,还有这个簇数组的指针是怎么搞?
修改时间 07-21-2010 09:27 PM
Only cluster is required to resolve this simple structure. Byte alignment is also required, since Labview only supports 1 Byte alignment in a cluster
