If you need what the table does, why not using table instead?
And, if you really must use listbox, you may try...
Hope above not confuse you 😉
Update... try refer to ...Get Double-Click Row.vi (using Multicolumn Listbox) at http://www.lvvilib.com/lvcodes.html#anchor-mclb
