NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
请教关于 DAQ PCI6221 的问题
我今天看PCI6221的资料,发现资料上说了这么一句话:“All three ground references—AI GND, AO GND, and D GND—are connected on the device.”我就不明白为什么那三个地是连在一起的,既然连在一起,为什么不只弄一个地端(弄那么多也很麻烦的嘛,呵呵)。
少壮不努力,老大徒伤悲
0 项奖励
1 条消息(共 6 条)
5,848 次查看
this remark tells that that card is not floating one.
that is available which makes many connected locations for you.
________________________________________________________
Try to make everything Automatic
0 项奖励
2 条消息(共 6 条)
5,842 次查看
谢谢了,你是不是说弄那么多端口是为了有更多的接线的地方,是不是啊?
还有“that card is not floating one”是什么意思啊? 3x
少壮不努力,老大徒伤悲
0 项奖励
3 条消息(共 6 条)
5,837 次查看
Yes.
let me think a channle to explain for you.
if the device is floating one ,example a "Scope", then ,it can test our AC voltage's waveform or the other parameter.
if not floating (share earth ground). it cann't be. high voltage will burn away the device.
0 项奖励
4 条消息(共 6 条)
5,833 次查看
呵呵,谢谢了
少壮不努力,老大徒伤悲
0 项奖励
5 条消息(共 6 条)
5,831 次查看
其实这个问题很简单
你找到这块卡的user manual
里面都它的结构图
0 项奖励
6 条消息(共 6 条)
5,815 次查看
