NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
请教数据采集问题
我用LABVIEW编的数据采集程序,当先运行中级采集程序后,再运行DAQ助手时就提示DAQ助手出错,提示代码为50103,请问那位前辈可以指点一下?
0 项奖励
1 条消息(共 3 条)
4,398 次查看
1,前一次采集没有正常结束.没有择放Buffer
2,第二次采集没有初始化,
3,第二产采集设置错误.
0 项奖励
2 条消息(共 3 条)
4,294 次查看
在max里reset一下device, 参看:
Error code: - 50103
Description:
The specified resource is reserved. The operation was completed by ignoring or overriding the specified resource.
Possible cause: The device is in use by another program/VI, or a previous DAQ task did not release the device resources.
Solutions: Make sure you have freed the device for use by another program or task instance. For example, you might not have wired a stop condition to a DAQ Assistant Express VI configured for single point acquisition.
0 项奖励
3 条消息(共 3 条)
4,284 次查看
