恳请各位xdjm解答,谢谢!
sample.uir包括两个panel,Constant Name分别为PANEL和TESTPANEL.
在PANEL上有个string,用
int GetCtrlVal (int Panel_Handle, int Control_ID, void *Value);
函数来取string的值时,书上写的是
GetCtrVal(panel,PANEL_STRING,string);
我不明白的是参数里的panel这个参数.它代表什么?为什么不是panelHandle呢?
generate all code时,Select panels to load....里的Panel Variable Name选项里的参数是什么意思?什么时候该用这个参数呢?
另外如果有几个panel的话,每个panel的Panel Variable Name参数在什么地方能够编辑呢?
我做过试验,好像上面函数里的那个panel用panelHandle也可以阿,为什么?
这个地方我实在是不明白,如果有什么资料的话,更加感激了,谢谢
int GetCtrlVal (int panelHandle, int controlID, void *value);
Obtains the current value of a control.
When the control ID is for a list box or ring control, GetCtrlVal returns the value of the currently selected list item. To obtain the index of the selected list item, use GetCtrlIndex.
Note This function is not valid for graph and strip chart controls. |
Input | ||
Name | Type | Description |
panelHandle | integer | Specifier for a particular panel that is currently in memory. You obtain this handle from LoadPanel, NewPanel, or DuplicatePanel. |
controlID | integer | The defined constant, located in the .uir header file, that you assigned to the control in the User Interface Editor, or the ID returned by NewCtrl or DuplicateCtrl. |
Output | ||
value | void * | The control value. The data type of value must match the data type of the control. |
Name | Type | Description | ||||
status | integer | Return value indicating whether the function was successful. A negative number indicates that an error occurred.
