NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
采集卡杂波来源
大家好!我是使用的是pci-6251进行信号采集,但是很多的杂波,而且在输入未接入信号源时都有杂波显示,是不是采集卡本身会产生杂波信号呢?可以通过哪些途径进行滤波呢?谢谢!!
to be better ,never the best for me.
0 项奖励
1 条消息(共 6 条)
4,967 次查看
You don't acquire channel(s) that not connected to any signal source, don't you?
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
0 项奖励
2 条消息(共 6 条)
4,964 次查看
是的,在我没有将通道连接到信号源时,在labview中都有信号信号显示,如果将连接两个通道的连线连在一起则信号正好反相抵消,请问这是什么原因呢?是不是受外界的信号干扰呢?
0 项奖励
3 条消息(共 6 条)
4,940 次查看
So, does it matters if there is floating signal (i.e. noise) in channels that are not connected to any signal source? I suppose that you are not acquiring channels without signal source, right?
And, what is the problem that you are facing?
Ian F
依恩与LabVIEW
0 项奖励
4 条消息(共 6 条)
4,929 次查看
Thank you for your reply , yes ,it  is also affected by the noise if they are not nonnected ot any sigal source, can you tell me how to do with it ?than you!
0 项奖励
5 条消息(共 6 条)
4,920 次查看
Will some proper grounding help?
Ian F
依恩与LabVIEW
0 项奖励
6 条消息(共 6 条)
4,915 次查看
