NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
随机启动程序
可不可用LabVIEW编写随机启动的程序?计算机打开时就运行,直到计算机关闭
0 项奖励
1 条消息(共 5 条)
4,654 次查看
Possible ways...
  • Create a Scheduled Tasks in your control panel; This runs the built exe/ program when PC starts. Or
  •  Use RT
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
2 条消息(共 5 条)
4,652 次查看
能不能详细、具体点啊!
Can't  you particular description this way?
0 项奖励
3 条消息(共 5 条)
4,641 次查看
Scheduled Tasks
You may add your built program (exe) as a scheduled task. This will runs the program automatically when the PC starts up.
Scheduled Tasks is found under Control Panel.
RT
Click above text.
Or Here
Message Edited by ian fung on 05-26-2009 11:29 AM
Ian F
依恩与LabVIEW
4 条消息(共 5 条)
4,639 次查看
I recommend putting corresponding shortcut to C:\Documents and Settings\All Users\Start menu\program\startup directory.
or write register ......\currentversion\run path......
________________________________________________________
Try to make everything Automatic
5 条消息(共 5 条)
4,628 次查看
