NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
高手快帮忙谢谢labview7打包后用到7中新的new report.vi的地方(选择的是word)都提示error 7 occurred at open vi reference in new report.vi
难过表情高手快帮忙谢谢
labview7打包后用到7中新的new report.vi的地方(选择的是word)都提示error 7 occurred at open vi reference in new report.vi。
下面提示的可能原因是Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on UNIX.
我愿自己是个胡萝卜,可以自己自足啦!
0 项奖励
1 条消息(共 6 条)
5,140 次查看
As you built the application, you haven't added support file for you installer. or software didn't find a target folder which you want to create a file in about one.
sum up . will occur your mentioning problem !
________________________________________________________
Try to make everything Automatic
0 项奖励
2 条消息(共 6 条)
5,132 次查看
原vi运行没问题啊。打成exe时就会出问题
我愿自己是个胡萝卜,可以自己自足啦!
0 项奖励
3 条消息(共 6 条)
5,129 次查看
He he , you don't know what my mentioning.
should you create a folder for a directory manual ? or create a ini file or Excel...parameter file manual ? and they are used in software ?
0 项奖励
4 条消息(共 6 条)
5,126 次查看
我明白您的意思,也可以按您所说的作,
但是open vi peference这个vi是labview提供的标准new report.vi的子vi中使用到的,如果我手动修改open vi peference中的提供的word路径,也就是说labview提供的模块也要自己修改了??
我愿自己是个胡萝卜,可以自己自足啦!
0 项奖励
5 条消息(共 6 条)
5,119 次查看
I don't know what "open vi peference" is . is "Open vi reference" ? if true, as you connect "current vi's path" ,Yes. its path is different from LV editor to built a installer .
0 项奖励
6 条消息(共 6 条)
5,114 次查看
