NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
About LV8.0 Toolkit
What time NI will issue LV8.0 Toolkit ? who knows ?
________________________________________________________
Try to make everything Automatic
0 项奖励
1 条消息(共 8 条)
5,897 次查看
rilee,
        Do you know about it ?
0 项奖励
2 条消息(共 8 条)
5,871 次查看
No sure what do you mean.  LV8.0 has been released.  You can download it from NI website.  You get 30 days try time.  After 30 days, you have to activate it.  LV addon toolkit usually released with LabVIEW.  LabVIEW Chinese version hasn't been released yet.  One of the LabVIEW R&D guy said they are woking on it.
George
George Zou
0 项奖励
3 条消息(共 8 条)
5,852 次查看
Already, you can got it from develope suite
0 项奖励
4 条消息(共 8 条)
5,848 次查看
Zou,
      Thank you for your tellings, and I already knew about LV8.0 evaluation edition one. and know its properties too.
my meanings it that, we are using LV7.1, maybe want to upgrade to LV8.0, I doubt whether the Toolkits which purchased with LV7.1 , it can be use in LV8.0 ?
if sure, we don't need to purchase more.
0 项奖励
5 条消息(共 8 条)
5,837 次查看
Most of them can be used on LV8(I test database connectivity and internet connectivity, they are works fine), but If you using vision development module 7.11 on LV8, I think you need to change some configuration of installation directory. then it also runs very well on LV8.
0 项奖励
6 条消息(共 8 条)
5,833 次查看
Oh. thanks a lot !
0 项奖励
7 条消息(共 8 条)
5,831 次查看
If you wanna know all NI LV toolkits and modules version information compatibility related with LV7.1 or LV 8.0, you could refer the website as follows:
0 项奖励
8 条消息(共 8 条)
5,766 次查看
