NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
Analog Input and Output
Hi Everyone:
I got a question for the example of Analog Input and Output that comes with 5640r.
I try to use the single Tone mode to generate sine waveform, it works really fine when I use scope to catch it.
However, the problem is when I change the sine waveform to square or triangle waveform, I can not get those waveform correctly.
For some reason, it still gives me sine waveform.
I am new to Labview, so sorry to ask this fundamental question.
Thanks for your help.
0 项奖励
1 条消息(共 5 条)
4,630 次查看
Hi fdfdfdf,
What exactly is the example you've used? Any screenshot available? And has the waveform ever changed after you changed the waveform from sine to square/triangle?
NISH AE
W. Yan
"spawn more overlords" means "create another subVI, dude", literally
0 项奖励
2 条消息(共 5 条)
4,588 次查看
HI, Sentica:
I am using the example called ni5640R Analog Input and Output
I changed the sinewave under Single Tone to square waveform.
0 项奖励
3 条消息(共 5 条)
4,579 次查看
The waveform is changing slightly, but it is still a sine waveform not square or triangle waveform.
0 项奖励
4 条消息(共 5 条)
4,569 次查看
Try immediately replacing Sine Wave.vi with Square Wave.vi in the "Single Tone" branch after reopening the VI without running it. Also make sure the input values are default.
Keep me updated 高兴表情
0 项奖励
5 条消息(共 5 条)
4,555 次查看
