NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
Architecture Puzzle as realize the functions of assistant or VBAI
Hello!
I want to realize the architecture as the picture shown. The above frame list many independent functions module, user can select the module at will through drag and drop into under frame. And user can randomly configure parameters of module, the main window return to background process, the
subwindow dap to the foreground. During changing the parameters , the picture show the effect dynamicly. when exit the subwindow, the main window
dap to the foreground .
Just as the above discription, the function of this application is just like the assistant or VBAI software of NI.
Please give me some suggestion!
Thank you!
In one application, one of functions modules may be invoked several times.
0 项奖励
1 条消息(共 1 条)
2,847 次查看
