NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
Can I achieve simultaneous analog input/output with two R Series devices?
Hi:   Now ,I want to Simutaneous AI Samples with two PXI 7851R module,
      how do I achieve it?
0 项奖励
1 条消息(共 4 条)
4,444 次查看
Hello, i am doing the same work as you.
You can find the example code as belows
LabVIEW's example finder-> hardware input and output->R series-> XXXXX.prj
there are some example codes which you can only do a little change and then be used by yourself.
And if you test the skew between two card, would you please let me know the number? Thank you!
0 项奖励
2 条消息(共 4 条)
4,348 次查看
I want 32 channels to simultaneous Sampling;
Now my  simultaneous time is more 100ns
so it cann't use in work
0 项奖励
3 条消息(共 4 条)
4,332 次查看
If your platform is PXI or PXIe, you could try to use the clock on chasiss (10MHz for PXI, 100MHz for PXIe), instead of sharing one on-module clock to another module.
0 项奖励
4 条消息(共 4 条)
4,307 次查看
