NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
DAQ6008
我的卡可以检测到直流信号,但检测不到交流信号,这是为什么呢。
帖子被dodo1dodo在09-23-2005 03:11 AM时编辑过了
0 项奖励
1 条消息(共 6 条)
5,650 次查看
i know who you're hehe, keep secret, ^_^
in MAX, select continuous mode instead of on demand. does it solve your problem?
0 项奖励
2 条消息(共 6 条)
5,629 次查看
sorry, fogot to say, is it possible to supply more infomation about you measuremnt on AC signal, sth. like screenshot, please?
0 项奖励
3 条消息(共 6 条)
5,627 次查看
对,最好能多提供一些关于信号以及前级连接方面的信息,否则无法判断清楚
0 项奖励
4 条消息(共 6 条)
5,620 次查看
吃惊表情i know who you are too.高兴表情
i changed AC signal to DC one in the signal generator. but i still can't get the correct one. so personally, it maybe not wrong with AC signal. i tried a puls generator produced by one of my classmate later, fortunately , i gained the expected one. however, it is too strange that why i can't the signal from signal generator. because i connect wires as the same way as you told me. i really appreciate your help.
帖子被dodo1dodo在09-23-2005 06:36 AM时编辑过了
0 项奖励
5 条消息(共 6 条)
5,618 次查看
我想知道你有没有使用抗混频滤波器?或者这个卡自带抗混频滤波器,如果这些频率没有被滤除,它们将会作为信号错误地出现在设备输入带宽中,你使用puls generator可以测到是因为不存在这样的现象,我想和交流还是有所不同吧。
A guitar man play instruments
wengang_qin@sjtu.edu.cn
0 项奖励
6 条消息(共 6 条)
5,603 次查看
