NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
DAQmx
在DAQmx中,这样才能初始化采集卡?
0 项奖励
1 条消息(共 4 条)
4,053 次查看
Use DAQmx Create Virtual Channel.vi
By specifying the physical channel(s) and its (or theirs) function i.e. Analog Input, Digital Input etc, its Task Out is then passing through for DAQmx Read, DAQmx Write etc to accomplish the desire tasks.
Try looking for shipped example(s) by searching for the keyword "DAQmx ".
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
0 项奖励
2 条消息(共 4 条)
4,046 次查看
Hi, Ian F
 Thanks for you explanation. i am using the CVI instead of labview. i am now trying to switch from Traditional DAQ to DAQmx.  so a lot of things are new for me. yesderay , i have found the function to reset the DAQ card, but i can not find the Time_out settings. and it looks the watch_dog setting only availabe for digital port.  😞
B.R
Gerry
0 项奖励
3 条消息(共 4 条)
4,031 次查看
Hi Gerry, perhaps, you may try posting your question to the LabWindows/CVI
Message Edited by ian fung on 10-30-2009 12:00 PM
Ian F
依恩与LabVIEW
0 项奖励
4 条消息(共 4 条)
4,020 次查看
