NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
How to open, grab image, and close 6 pcs of USB camera one by one by LabVIEW
Dear All,
I have a project, and want to use Labview to program it. The project need 6 USB cameras to grab images, but it is strange that the Labview cannot open cameras stably, if I use cameras with 300K pixies solution or up, even if the program open, close these cameras one by one. Normally, the program wait a while and display "timeout"!!
Please help! Urgent! Otherwise it will be another failed case to attempt implementing LabVIEW.
Thanks!
Bill Han
0 项奖励
1 条消息(共 4 条)
5,891 次查看
Test in MAX first.
Increase expose time.
I did 2 cameras, 640x480, early this year.  Camera link, not USB.
George Zou
0 项奖励
2 条消息(共 4 条)
5,880 次查看
2个相机的连接跟我的情况很不一样,因为即使是2个USB相机也可以很好工作。但是如果是6个USB相机情况就完全变了,特别奇怪的是,即使我一台一台地打开、图像采集、关闭相机,也不能稳定工作。这是LabVIEW本身的问题吗?
我不知道GigaE的方案可以支持多少相机,可能6台没有问题,但是成本就是USB相机的几倍了。
所以,请各位高手帮忙分析一下问题!
谢谢!
0 项奖励
3 条消息(共 4 条)
5,875 次查看
应该是USB的带宽不够,我弄过8个USB相机,加USB扩展卡试试。
GigE Vision也是取决于带宽。
CLD
CAU
0 项奖励
4 条消息(共 4 条)
5,731 次查看
