I use vision builder to build a pattern seach VI, but the VI only search the pattern that register in vision builder. In labview Controls Palette,i can't find some thing to solve this problem.
I need you help,thank you!
In the following function block proceed to perform the extraction of the pattern with a function for image processing that captures the last event of the RGB (extract image and coordinates)
