NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
How to using Labview8.0 to open LabView8.6 VI?
I use LabView8.0 version and i have Thermal machine driver VI (This driver is base on LabView 8.6).
I can not open it with labview8.0.
Pls help me to using 8.0 version to run  8.6 VI
THX
怎么样用labview 8.0 打开 8.6的 VI?
谢谢!
0 项奖励
1 条消息(共 4 条)
4,434 次查看
hi, you need someone to down-convert it to you.
if the driver i.e. LLB is not too big, you may upload it here.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
0 项奖励
2 条消息(共 4 条)
4,419 次查看
What tool shall i needed?
0 项奖励
3 条消息(共 4 条)
4,371 次查看
You only need to do just as ian fung said:
You need a LabVIEW 8.6 or 2009 to open the 8.6 version VI, and down convert it to 8.0 version
so if convert work is not too heavy, you can upload it up to the forum, maybe we can help you with that
Best Regards
Hu Yu
0 项奖励
4 条消息(共 4 条)
4,364 次查看
