NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
IMAQ Setup Learn Geometric Pattern VI和IMAQ Setup Match Geometric Pattern VI有什么区别?
请问,IMAQ Setup Learn Geometric Pattern VI和IMAQ Setup Match Geometric Pattern VI有什么区别?为什么有时不用IMAQ Setup Learn Geometric Pattern VI而直接用IMAQ Setup Match Geometric Pattern VI?
0 项奖励
1 条消息(共 2 条)
3,915 次查看
If the template image, which contains the data that defines the template pattern for the matching phase, does already exist, there is no need to IMAQ (Setup) Learn Geometric Pattern VI.
The "Match Multiple Geometric Patterns Example.vi" is a good example for you.
帖子被tao hou在 03-18-2010 10:31 PM
时编辑过了
Best Regards,
Tao Hou
NISH
0 项奖励
2 条消息(共 2 条)
3,901 次查看
