NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
LINUX下的汉字支持一直无法解决,大家有何办法?
Turbo LINUX Desktop 10(OSver 2.6.0)前面板输入汉字报错:fontmgr.cpp(5505)
#Date: Thu, Jun 09, 2005 06:12:09 PM
#OSName: Linux
#OSVers: 2.6.0-1
#AppName: /usr/local/lv70/labview
#Version: 7.0
#AppKind: FDS
fontmgr.cpp(5505) : DAbort: Probably walked off end of ofstP array
$Id: //labview/branches/Wormhole/dev/mgsource/fontmgr.cpp#52 $
0x081D8597 - + 0
0x081D9B17 - + 0
0x081D7D9D - + 0
0x081D7FB2 - Recalc + 26
0x0825D195 - _Z23LVHostDrawable_DrawTextPP6Text_t + 49
0x081C6A15 - TDraw + 11
0x086D84CA - _Z20LabelHandleTextEventPPhiP4ARGSi + 406
0x086E0F97 - _ZN9LabelMeth4DoitEPPhiP7OBJPATHiP4ARGS + 10F
0x086CECA3 - _Z5oDoitPPhiP7OBJPATHiP4ARGS + 63
0x086E3E7F - _ZN8SupCMeth4DoitEPPhiP7OBJPATHiP4ARGS + 13B
0x088B6472 - + 0
0x088B6324 - _Z19ContinueTransactionPPhP7OBJPATHiP4ARGS + 28
0x085F7CAE - _Z5DoKeyP6WEventPPhPi + 446
0x0891EE53 - + 0
0 项奖励
1 条消息(共 2 条)
4,782 次查看
LabVIEW 6.1 for Linux does not officially support Chinese characters. Depending on the version of your Linux OS, the problem might be fixed by modifying the Language Option and the Local Setting, but in the case of RedHat 8.0, there is currently no way to display correct Chinese characters in LabVIEW 6.1. The Chinese version of Turbo Linux is an example of a Linux OS that will support Chinese characters in LabVIEW 6.1.
The same problem also occurs with other East Asian Languages.
0 项奖励
2 条消息(共 2 条)
4,766 次查看
