NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
LOG问题
VI运行时最左上角的图标能去掉吗?
党教育我们要忠于人民
0 项奖励
1 条消息(共 12 条)
6,121 次查看
那个图标在创建可执行程序的时候可以被改变,在Application settings中有Custom Icon一项。
0 项奖励
2 条消息(共 12 条)
6,100 次查看
谢谢rilee
再请教个问题
打包生成安装包时候能不能设置安装界面上为中文显示?
党教育我们要忠于人民
0 项奖励
3 条消息(共 12 条)
6,095 次查看
rilee,
        I am interesting about that, and I tried it. the result is fail, no matter what I used a tool to generate an image which is 16X16 or 32X32 and 16 bit colors ???????
the left corner indicates NI logo also !!!
________________________________________________________
Try to make everything Automatic
0 项奖励
4 条消息(共 12 条)
6,079 次查看
是的,我尝试过也没有变化。
Yukee,你知道怎么设置能把安装界面改成中文的吗?
似乎只有英,日,法德吧?
为什么小日本都比我们待遇好。。。
党教育我们要忠于人民
0 项奖励
5 条消息(共 12 条)
6,077 次查看
I havn't tried it. cause We havn't this demand. as I know that your demand is leading to your LabVIEW system's original langue, if your labVIEW is English, it is english only !
0 项奖励
6 条消息(共 12 条)
6,065 次查看
可以呀,不过对图标的要求比较高,必须是32×32格式以及16×16格式的
做了一个小程序
0 项奖励
7 条消息(共 12 条)
6,060 次查看
OK. good. Thank you. I will try again !
0 项奖励
8 条消息(共 12 条)
6,055 次查看
rilee,
        Today I tried to add the *.ico which is 16 colors and 16X16 for installer, it is successful, but ...
if I add 16X16 ico for it ,cann't add 32X32,
add 32X32 ,but cann't add 16X16. can they be added together ?
0 项奖励
9 条消息(共 12 条)
6,018 次查看
yeah, for sure
but be sure that 32*32 and 16*16 icons are all in one icon file. hehe
Is it possible for you to try a CVI tool, which named 'Icon Editor'?
it can solve all problems you encountered.
0 项奖励
10 条消息(共 12 条)
6,013 次查看
