NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
Let's make a game as your method as mine ?
Yes. You are right. but we must know, make a game is not for playing of labVIEW, or pass your time, just practise your logical ability and be familiar with labVIEW's function.
________________________________________________________
Try to make everything Automatic
0 项奖励
11 条消息(共 15 条)
3,361 次查看
I agree.
0 项奖励
12 条消息(共 15 条)
3,360 次查看
You have finished a very interesting game,how can you build it?
0 项奖励
13 条消息(共 15 条)
3,357 次查看
Firstly, I work to know how the moving array's order is. calculate every array's address out. it has its moving order.
using string function to get the solid address, build them to 2D array. then index two column array and two row array which are all the side by the 2D array ( string address array).namely ,index round of the 2D array's array,  when you achieved index an action, delete a history. the other round of array address's process is all the same. the last reshape indexed array to 1D. secondary, input the reshaped 1D array address to "replace array" function. then you got it.
0 项奖励
14 条消息(共 15 条)
3,355 次查看
I will try your method
0 项奖励
15 条消息(共 15 条)
3,353 次查看
