NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
NI 9505 position Close loop control
I use NI 9505 control brushed DC Servo motor, i use example programme PWM Generation and Velocity Control (open loop), the programme can run. but when i run Position Control (closed loop), motor run ,but some times can not stop. I found in programme ,Position loop while loop, the current command output from PID is not stable, some times change to big value number, i want to see the PID Programme, but it protected by password. so ,anyone use Position Control (closed loop) to control motor ,can contact with me. my email address: ygsh16@hotmail.com, handphone is 065-91204219(singapore) BTW, my motor encoder is TWO CHANNEL ENCODER CONNECTIONS: 1. BLACK : - MOTOR 2. RED : + MOTOR 3. BROWN : HALL SENSOR Vcc 4. GREEN : HALL SENSOR GND 5. BLUE : HALL SENSOR A Vout 6. PURPLE : HALL SENSOR B Vout how this encoder wiring connect with NI9505? Thanks
0 项奖励
1 条消息(共 1 条)
3,019 次查看
