你好!
你说的问题是因为daqmx base 1.0.1版本的问题,您可以从http://digital.ni.com/softlib.nsf/websearch/1EAE5E3990B2039B862570AC00514361 下载daqmxbase 2.0,这个是支持pocket pc 2003的,labview8下的驱动,labview 7.1也应该能用,但我还没试过。
在更新驱动前,先尝试http://digital.ni.com/public.nsf/websearch/E8E3AA97EA29D7D686256E9000698B3C?OpenDocument ,
(i'm sorry i can't use Chinese language now,hehe)or restart your PDA when you got above error,sometimes it works.
and suggest you to test with another PC, normally which can be solved w/o driver update to daqmx base 2.0.
please let me know whether you solved your problem, 3x!
have a great day!
Thanks for your answer first.
The ways your refered in "http://digital.ni.com/public.nsf/websearch/E8E3AA97EA29D7D686256E9000698B3C?OpenDocument " was tried several times,but the erorr still occur.
The followings are substract from the readme file of "NI-DAQmx Base 2.0":
| NI Application Software | Versions Supported by NI-DAQmx Base 2.0 |
| LabVIEW | 7.x or 8.0 |
| LabVIEW PDA for PocketPC | 8.0 |
| LabVIEW Real-Time for RTX | 8.0 |
"NI-DAQmx Base 2.0 supports PCMCIA E-Series cards and the Compact Flash CF-6004 on Pocket PC 2003 with LabVIEW 8.0 PDA. The development environment runs in LabVIEW 8.0 and is supported on Windows 2000 and XP".
The problem is that My PDA module is LabVIEW 7.1 PDA, and development enviroment is LabVIEW7.1, can I still use the DAQmx base 2.0?
Thanks!
