NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
PXI-1033 will cause a IRQL_LESS_OR_NOT_EQUAL blue screen error on Windows XP SP3
I installed the driver in below steps:
1. Install PXI1033 drivers on Windows XP SP3
2. Enable PAE (Physical Address Extension)
3. Restart system, then the system will run into blue screen with an IRQL_LESS_OR_NOT_EQUAL error.
The system works fine if PAE is disabled.
Does anyone experience this problem?
0 项奖励
1 条消息(共 2 条)
3,156 次查看
您好
这中错误通常出现于32位的操作系统上:http://digital.ni.com/public.nsf/allkb/8355753BD0C8E62F8625768C005B359B?OpenDocument
请禁用PAE
AE
NI Shanghai
0 项奖励
2 条消息(共 2 条)
3,136 次查看
