There are two functions, StartPCsound and StopPCsound, in the Programmer's toolbox that allow you to pick a frequency, output sound, and then stop it after a specified duration. These functions use the Inp() and Outp() functions, so under Windows NT the CVI Device Driver is required.
Other options would be to use the Windows SDK functions for accessing a Sound Card. See the example on this topic from the NI Developer Zone (linked below).
Developer Zone Example: Play .wav Files Using Windows SDK Functions
my problem is to send 2 signals to the sound card and later captured. Sending a signal to turn the sound card and using a jack male male I can acqusirli. Here are the two functions used
int AudioOut(int samples, short int wave[])
HWAVEOUT handle;
WAVEFORMATEX formato;
WAVEHDR BufferSuono;
char ErrorString[200];
formato.wFormatTag = WAVE_FORMAT_PCM;
formato.nChannels = 1;
formato.nSamplesPerSec = sampling;
formato.wBitsPerSample = 16;
formato.nBlockAlign = formato.nChannels * formato.wBitsPerSample / 8;
formato.nAvgBytesPerSec = formato.nSamplesPerSec * formato.nBlockAlign;
formato.cbSize = 0;
errore = waveOutOpen(&handle, WAVE_MAPPER, &formato, 0, 0, CALLBACK_NULL);
if (errore)
waveOutGetErrorText(errore, ErrorString, 500);
BufferSuono.lpData = (LPSTR)wave;
BufferSuono.dwBufferLength = samples * 2;
BufferSuono.dwFlags = 0;
errore = waveOutPrepareHeader(handle, &BufferSuono, sizeof(WAVEHDR));
if (errore)
errore = waveOutWrite(handle, &BufferSuono, sizeof(WAVEHDR));
if (errore)
while (!(BufferSuono.dwFlags & WHDR_DONE));
errore = waveOutReset(handle);
if (errore)
errore = waveOutClose(handle);
if (errore)
return (0);
nt AudioInAndReturn(int samples, short int wave[])
formato.cbSize = 0;
errore = waveInOpen(&handle, WAVE_MAPPER, &formato, 0, 0, CALLBACK_NULL);
if (errore)
waveInGetErrorText(errore, ErrorString, 500);
errore = waveInPrepareHeader(handle, &BufferSuono, sizeof(WAVEHDR));
if (errore)
errore = waveInAddBuffer(handle, &BufferSuono, sizeof(WAVEHDR));
if (errore)
errore = waveInStart(handle);
if (errore)
return(0);
My problem is to send 2 signals simultaneously,with a stereo transmission,and then acquire them.
Help me. I do not know how to do
