修改时间 11-23-2009 12:47 AM
已解决! 转到解答。
修改时间 11-23-2009 01:37 AM
You will need some coding based on the property (of the table) i.e. index values or edit position and the number of display and data rows.
PS: Attached is one example that uses multicolumn listbox instead of table. FYR
