NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
The CVI example of NI435X can not work correctly
The CVI example of NI435X can not work correctly.
I have a PXI-4351 card,  I do not have an accessory box connected to the 4351, the  thermocouple is wired direct to the pins on channel 1 of the PXI-4351.   I want to read the measurement from a K type thermocouple .
I first use the MAX Test Panel,  the panel shows the  temperatures correctly ; Then I close the MAX Test Panel, use the CVI example of the NI435X --- Measure (without Accessory), The CVI example can not work correctly, it shows error temperatures ;then, i use the VB example of the NI435X --- Measure (without Accessory), It give me the error result too; finally, i use the LabView example of the NI435X --- Measure (without Accessory).vi, it works correctly!!!
My NI435X version is 2.5.1 and 2.5.2, the same thing happened on the both version.
Is there any BUG in the CVI example and  VB example? How to resolve it? I want to write my application in C or VB.
Thanks!
0 项奖励
1 条消息(共 1 条)
3,140 次查看
