NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
VISA aways have waring
In my max, VISA aways have waring
error code is 0x3FFF0077 (VI_WARN_CONFIG_NLOADED)
Description of error is
viOpenDefaultRM returned 0x3FFF0077 (The specified configuration either does not exist or could not be loaded. VISA-specified defaults will be used.)
This error usually occurs when a Passport either could not be found or could not be loaded.  All configured Passports were loaded correctly.  Try refreshing the configuration tree to find your VISA resources.  If this warning still appears, your VISA installation may be corrupted, and you may have to reinstall your software.
Possible reasons for this warning:
1. A Passport was either renamed or deleted.
2. A Passport depends on other components in your system that are no longer present.
3. Your installation of VISA is corrupt, i.e. an internal registry key is missing or changed.
4. An older installation of VISA may have caused this warning without specifying more information.  Try refreshing the configuration tree to get more information.
哪位大虾知道这是啥意思,怎样解决?谢谢
0 项奖励
1 条消息(共 2 条)
4,297 次查看
请重新安装一下NI-VISA,看一下问题是否能够得到解决
0 项奖励
2 条消息(共 2 条)
4,260 次查看
