NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
builder hang
I use labview 7.1 , nidaqmxbase 1.5  on a LINUX system
I use a NI PCI 6220 DAQ
i detect a problem when i want to build a vi using the nidaqmxbase "start task vi". The builder finish with the message "error 1003 with  67xx  boardconfig vi  possible reason the vi is not executable....
Why 67XX ???
the application run well in labview environment
I try to made an " alt shift run" on the application  and it also hang, even if  there is only this subvi "start task.vi";
I also made an "mass compil" of the daqmxbase directory  no result
The builder hang also on an vi example "acq one sample.vi" with the same message. this example use the "start task .vi " . It doesn't hang anymore when  I supress this subvi...or when it run in labview environment.
Is it a basic bug ?? have a solution ??
I don' t find any solution on the forum...
Im quit deseperate because i lost a lot of time because of this
BERNARD ROSSINI
0 项奖励
1 条消息(共 3 条)
3,872 次查看
try this:
Go to the Application Settings tab of the application builder and uncheck the box to "Disconnect type definitions and remove unused polymorphic VI instances".
but I'm not sure whether it works or not.
by the way, what the function " alt shift run" is?
0 项奖励
2 条消息(共 3 条)
3,867 次查看
This case was yet uncheck because i had an "other" hang of builder !!!
alt shift RUN (white arrow) on the application run a compilation of it.... (alt on linux ctrl on window)
I tried to make the same on a LV 7.1 for XP  and i have the same hang up ?!!!
is it a basic problem  of LV or not ?
or perhaps a problem of interface (DAQ) installation ?
Do I have to install DAQ  AFTER nidaq installation ?
I shall search on this way
Bye
BR
0 项奖励
3 条消息(共 3 条)
3,858 次查看
