NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
detailed instructions of function
I have read some examples given by NI, one of them is about how to continuously acquire pictures using a low level grab operation, when I want to add the codes into my own procedure,I found that I 'm not very clear about many functions in that, may anyone give me the instruction of those functions?
The example I mentioned about is LLGrab of NI PCI-1424 ,I'll be very apprediated if someone can explain the usage of those functions in tha examples.
By the way,the material I've got now is only the CD along with PCI-1424 when I bought it .The CD contains NIIMAQFuctionReference, in which the functions are described superficially, but I want instruction much more detailed.
0 项奖励
1 条消息(共 2 条)
3,290 次查看
For most, if not all, properly done functions (VIs), you may read its context help by pressing [CTRL+H] and mouse over the function VI's icon...
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
0 项奖励
2 条消息(共 2 条)
3,275 次查看
