NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
difference among graph,chart and XY graph
The difference among graph,chart and XY graph
I am doing a data collection work . And I need to draw a graph or a chart with the data . But I can't make a choice.
If I draw a real-time graph, which is the best.  And in which situation I use the others.
Thanks a lot !!!
0 项奖励
1 条消息(共 4 条)
4,611 次查看
They are not a compactly definiendum. as your test station's condition to select.
draw a real-time graph, I suggest that Chart is OK.  as a data in. it will draw a point out.
________________________________________________________
Try to make everything Automatic
0 项奖励
2 条消息(共 4 条)
4,607 次查看
Thank you Master Yukee , I know .
But what 's the difference between the XY Graph and Graph?
And when I choose Graph to use ?
0 项奖励
3 条消息(共 4 条)
4,600 次查看
The details are many many. and I cann't tell about one by one at nonce.
you can search the difference from NI web, or the other technology materials. Yes. ^.^
0 项奖励
4 条消息(共 4 条)
4,598 次查看
