NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
fpga
 I get Error 7 when I  try to  the   run    vi  in    fpga for the first time .
I reinstalled  all the software, LV 8.6.1/RT mould modular 8.6.1/FPGA 8.6/DAQ 9.0/NIRIO 3.2.1,but  the same error  was shown again.
The complete error is:
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Error 7 occurred at Error calling module generator VI: NULL
Possible reason(s):
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
0 项奖励
1 条消息(共 2 条)
3,409 次查看
I  find the answer from
 http://forums.ni.com/ni/board/message?board.id=170&message.id=423223&requireLogin=False
“This looks really familiar.  I know I've seen this error.  I think there is an issue if you upgraded to the latest NI-RIO but you didn't upgrade LV FPGA from 8.6.0 to 8.6.1, or something like that.  Could that be it, kmoyna? ”
0 项奖励
2 条消息(共 2 条)
3,406 次查看
