NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
labview USB-6361
0 项奖励
1 条消息(共 3 条)
1,835 次查看
I can't read any of the details but I *can* tell you the following about your X-series USB-6361 device:
1. Hardware timed DIO is *only* supported on port 0, not on port 1 where you've configured it.
2. The maximum sample rate supported is 10 MHz.  You won't be able to use the 20 MHz timebase as a sample clock.  You *can* request a 10 MHz rate and leave the clock source input unwired.
-Kevin P
2 条消息(共 3 条)
1,798 次查看
DAQ定时vi的采样模式选连续采样,不要把所有vi放到循环中,仔细看看范例,
0 项奖励
3 条消息(共 3 条)
1,762 次查看
