NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
labview nxg 中将数据库范例中的gvi添加到自己新建项目中,出现依赖项包含错误提示。
具体为nxg 范例—基础编程-互联-数据库-读取数据库,那里面的几个例子都不能用自己创建的工程加载,加载就出现依赖项错误,只不过工程不在一个工程里,其余的什么变化都没有。
0 项奖励
1 条消息(共 6 条)
3,099 次查看
0 项奖励
2 条消息(共 6 条)
3,015 次查看
My NXG doesn't see the problem.
Why don't you fix NXG on NI Package Manager?
Certified LabVIEW Developer
GCentral
0 项奖励
3 条消息(共 6 条)
3,004 次查看
thank u!
But,it doesn't work.
Furthermore,i find that the build-in examples  work well , but when i copy the example to my new VI project, the problem occour.微信截图_20200325160625.png  And when in the build-in example , the deleted data  works well,but in my new VI project, i will see the problem.
0 项奖励
4 条消息(共 6 条)
2,997 次查看
Umm... Very strange behavior...
I looked for the source and found here.
C:\Program Files\National Instruments\LabVIEW NXG 4.0\Addons\NI\G\databaseconnectivity-src\1.0.0.0
I guess file path might be root cause but no confidence...
When create new project in non Chinese named path, do you see the behavior...?
GCentral
0 项奖励
5 条消息(共 6 条)
2,995 次查看
Thanks for your advice.
But it has nothing to do  with file path,I  create new project in non Chinese named path, the problem can't be solved.
Actually,I saved the build-in example on my desk and its file path includes  Chinese named,微信截图_20200325174254.png
and then, i deleted all the program and wrote a simple program on the example project with delete data fuction , strange thing happened, it works very well, the problem disappered.
But i don't know what happened to my new created project, i think there is no different between new project and example project which has been deleted all the program.
0 项奖励
6 条消息(共 6 条)
2,992 次查看
