NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
lvdaq.dll cannot find in the win10 system after install labveiw 2019
hi guys,
I am using labview 2019, when i use call library function node to call lvdaq.dll, it failed, do you how to fix this issue, where i can find the right lvdaq.dll to match with labview 2019 and  win10 32bit/64bit,thanks
0 项奖励
1 条消息(共 2 条)
1,984 次查看
You should not call the dll yourself.  It's for legacy DAQ.  I don't know if it works on Windows 10.  It's too old.
You should use DAQmx 2019 for LabVIEW 2019.
George Zou
0 项奖励
2 条消息(共 2 条)
1,946 次查看
