NI Labs Discussions
1794-AENT/B And Labview Ethernet I/P
I'm trying to read IO from a AB/Rockwell 1794-AENT/B Ethernet/IP interface module with an 8 port analog module attached.  I've gotten my VI to where I can read the status register and identify that I'm talking to the interface module.  I can't seem to figure out how to read the IO module data.  Can anyone share an example VI?
The remote IO is a Rockwell 1794-AENT interface module and a Rockwell 1794-IE8K IO module. I'm using the EtherNet/IP library from NI.  I can read the 1794-AENT status registers, like the module name, version number etc.  What I can't figure out is how to read the data from the analog IO module.
Thanks for the help.
Greg
CVC
References:
http://samplecode.rockwellautomation.com/idc/groups/literature/documents/in/1794-in082_-en-p.pdf
http://www.pacpro.com/upload/data/Rockwell%20IO/FlexIO/Ethernet_1794-AENT%20User%20Manual.pdf
http://samplecode.rockwellautomation.com/idc/groups/literature/documents/rn/1794-rn059_-en-p.pdf
G Yotz
Message 1 of 1
(4,467 Views)
