NI Labs Discussions
CPX Festo Ethernet/IP - Labview
I'm trying to set up connection between PC and Festo CPX-FB36 (with Ethernet/IP)
I linked the module via MODBUS TCP , and it worked correctly all the outputs and valves were activated.
For Ethernet /IP it is configured as follows .
 CPX-FMT configuration
with this the communication is established, now all that is missing is the sending of data, to activate outputs and valves.
does anybody have any suggestions?
Message 1 of 11
(10,520 Views)
hello ,
are you find a solution ?
because i have the same situation and  i dont know how can i use CPX Festo with LV,
thanks
Message 2 of 11
(10,009 Views)
Yes i finding to solution with modbus tcp and ethernet /ip
Message 3 of 11
(9,991 Views)
please can you give me a project or tutorial how can i use it because i'm beginner in labview and i dont know how to use it , thanks
Message 4 of 11
(9,970 Views)
is it possible to send this VI to me? would appreciate it.
Message 5 of 11
(8,653 Views)
good day
I can send you the VI file, I have also done it with SMC interfaces, it is quite easy, and also with Ethernet/IP SMC, FESTO, Mitsubishi controllers, etc, they have to be with Ethernet/ip protocol.
best regards
Message 6 of 11
(8,639 Views)
can you post it here or do you prefer my email?
Message 7 of 11
(8,627 Views)
Can you post your solution (or VI) here? I have a similar issue so it might help me, and others in the future, too.
Thank you!
Message 8 of 11
(7,921 Views)
hello, the only problem I had when developing the project is the attribute and the class, this is focused on ethernet/ip CIP so it was not in the manual.
best regards
you can send me an email
imartinez@integracionid4.com
Message 9 of 11
(7,830 Views)
Can you please send also to my address the solution?
perelliraffa@yahoo.it
Message 10 of 11
(7,344 Views)
