02-01-2015 11:43 PM
This block-diagram has an error. But I can't fix the this code.
I wonder how can i fix the program.
And others.. Releasing a trigger high signals, voltage signals output.
02-02-2015 01:42 AM
Hi Yulslaw,
The top DAqmx task you are creating is an Analog Output (write) task, but in the while loop you are trying to perform a read. Try changing that function to a write or the task to a read and this should work.
Hope this helps,
Nick
02-02-2015 02:52 AM
Thank you
