NI Labs Discussions
Modbus RTU RS-485 Help
Hey Rhiesnand,
I'd recommend moving this discussion to the forums here (https://forums.ni.com/t5/Industrial-Communications/bd-p/260) where your questions will get more exposure and therefore you'll get more help.
I'd also recommend using one of the many libraries for modbus. LabVIEW DSC and RT have I/O servers which will do all of the work for you, and if you need fine-grained control there are many options available:
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
http://sine.ni.com/nips/cds/view/p/lang/en/nid/210229
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201711
Daniel
Message 11 of 17
(6,370 Views)
i am trying to communicate delta plc with labview using rs232 or rs 485 but no success, can you please guide me
Message 12 of 17
(6,370 Views)
Hey Faizi89,
Please post your question here: http://forums.ni.com/t5/Industrial-Communications/bd-p/260
This community (NI Labs) is not actively monitored.  Also, please try to add some additional details, eg specifics of what problems you are seeing.
Thanks, Daniel
Message 13 of 17
(6,370 Views)
Hi rhiesnand, im doing similar project like what you did, but my labview dose not comunicat with my PLC, simply modbus master is easily communicating, but on labview im sendig the same request code that modbus master is sending, but there is response.Untitled.png
Message 14 of 17
(6,370 Views)
im doing similar project like what you did, but my labview dose not comunicat with my PLC, simply modbus master is easily communicating, but on labview im sendig the same request code that modbus master is sending, but there is no response.
If there is no solution, Maybe I try it with SCADA
Message 15 of 17
(6,370 Views)
yes , IGSS solved my commection problem. thank you for everybody's reply
Message 16 of 17
(6,370 Views)
Great solution, THESE WRITING ON A SERIAL PORT HEXADECIMAL, many words should be written ?, INDUSTRIAL EQUIPMENT SOME WORKING WITH SPEED DATA TRANSMISSION 19200, DID YOU HAVE TO SET THE SPEED ALSO?
Message 17 of 17
(6,370 Views)
