NI Labs Discussions
NI-Industrial Communications for EtherNet/IP
I have used Ethernet/IP drivers version 1.1.0 and that worked under Labview 2009. Since I use now Labview 2011 for my projects I am trying to use the latest version of these drivers (version 1.2). The problem I came across is that once I finish the installation I see that I have the latest version installed under my system but when I try to install the software on the remote device, in this case a PXI-8108, the only option available to install is still version 1.1.0. I have tried uninstalling the previously installed 1.1.0 and install 2.1 from scratch but I still can not see the option under MAX. I have tried running a test VI anyway but it doesn't work.
Can anyone help me?
thanks
Simone Primavera
Control Engineer
Tri Alphae Energy
Message 1 of 1
(3,821 Views)
