NI Labs Discussions
NI PXIe 7965R for emulation
I want to develop applications for NI Flex RIO PXIe 7965R in emulation mode as I don't have any hardware connected to my system but while creating FPGA project I am selecting create new system under which only PXI- 795xR series is available. How can I get the PXI-796xR series targets for my project?
As after testing in emulation mode I will run this applications in other system where PXie 7965 FPGA board is connected, so that I can directly export the project to other system otherwise I can export only the VI's where I should create new project under which I should add necessary memory elements each time.
Thank you,
Chandrasekhar R Patlolla.
(8,519 Views)
please post this question in the normal NI Discussion forums found here. forums.ni.com
(3,560 Views)
