NI Labs Discussions
Welcome to NI Dynamic Signal Acquisition Soft Front Panel
20170517 update released to address cosmetic issues and add support for new measurement types such as charge and charge-mode accelerometers supported by PXIe 4480.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
Message 11 of 25
(6,549 Views)
2018 update published!
Both applications were built for 64-bit which allows for larger data sizes. (now requires LabVIEW 64-bit run-time engine)
Launch the SFPs for your DSA hardware from MAX.
Some other cosmetic and usability issues addressed. If you observe issues or have requests, post here to let us know!
Doug
Message 12 of 25
(6,238 Views)
Note, the DSA and DSG Soft Front Panels are freely provided to let you use NI DSA hardware with no programming.
Recommended devices for dynamic signal generation:
PCI 4461
PXI 4461
PXIe 4463
USB 4431
NI 9260
Recommended devices for dynamic signal acquisition:
PCI 4461
PXI 4461
PXI 4462
PXI 4492
PXIe 4464
PXIe 4480
PXIe 4492
PXIe 4497
PXIe 4499
USB 4431
USB 4432
NI 9232
NI 9234
NI 9250
NI 9251
and more....
Doug
Message 13 of 25
(6,235 Views)
I'd like to use DSG and DSA at the same time. Seems like this should be doable but I get errors about shared resources. Isn't it possible to run a signal on the DSG and then collect data at the same time on the DSA?
thanks
Jason
Message 14 of 25
(6,166 Views)
This is absolutely supported. Sometimes, when using the SFPs on the same piece of hardware like a 4461 which supports AI and AO, the DAQmx driver coerces the specified sample rate such that I have to tweak my rate in whichever panel I run second. Post your exact error message, and maybe we can provide more directed guidance.
In fact, you can even run multiple DSA SFPs and multiple DSG SFPs simultaneously.
Doug
Message 15 of 25
(6,163 Views)
Also, just to verify, you are running the executables as opposed to the sample project VIs.?.
Doug
Message 16 of 25
(6,161 Views)
Doug
Message 17 of 25
(6,159 Views)
can you generate frequency response plots aka transfer functions using NI DSA Soft Front Panels? Not just the FRF from an acceleromter but rather the TF for two accelerometers say from a shaker and and cantilever beam.
thanks
Jason
Message 18 of 25
(6,158 Views)
The executable does not, but one can modify the SVT sample project to do that. Also, there are examples in LV and in SVT that compute the transfer function (see also frequency response).
Doug
Message 19 of 25
(6,155 Views)
Thanks Doug
That is too bad. I like the idea of the soft front panels. My colleagues use much more sophisticated software (from competitors?) that is over kill from a classroom perspective. The DSA works nice but that one addition of generating a transfer function from shaker or impact hammer would make it perfect.
I can do it with Signal Express and make it pretty no brain to setup for students. I have limited Labview programming skills and the students have very little. The course is focusing on Vibrations not Programming.
thanks though. I just wanted to make sure I wasn't pushing the wrong button.
Jason
Message 20 of 25
(6,151 Views)
