NI Labs Discussions
Welcome to the LabVIEW FPGA Sync Register Tool
The LabVIEW FPGA Sync Register Tool places labels on every IO Node in a VI so that a developer can quickly view all of the timing and synchronization registers in their circuit without having to individually open each IO Node's property page.  This thread is intended to foster discussion about the project. Please post your questions, suggestions and applications here. Our team including R&D, marketing, and support will actively monitor this discussion.
Donovan
Product Support Engineer - LabVIEW FPGA R&D
Donovan
(10,527 Views)
HI all,
I've installed NI VISA 3.3.0 and the Sync Register Tool. I've just open the CLI¨P adder example, and I do not see any more informations in the diagram regarding registers. I even restarted my computer.
Is there some configuration to make it run correctly ?
Thanks for your answer.
Cordialement,
Raphael T
(4,488 Views)
I've Just solved it.
Just need to go on the menu "Tools - Expose Sync Register".
Thanks.
Cordialement,
Raphael T
(4,488 Views)
Hi Jabba,
Once you have your project and VIs open, you'll need to go to Tool»Expose Sync Registers...  Then a dialog will come up populated with all of your open VIs and you can select which terminals to show the number of registers on.  I'll update the tool page to include this information.
Donovan
Donovan
(4,488 Views)
