NI Labs Discussions
help....
m doin a sbrio project in which i will b using bug algorithm....for dis algorithm i need 2 locate d target 1st n den hav 2 avoid d obstacle....n my guide has told 2 use only ultrasonic sensor....how m goin 2 locate d target can u plz provide sum help 4 dis......is there is option in labview robotics in which i can set the coordinates upto whre the robot has 2 travel...it urgnt sir plz help
(3,554 Views)
This is not the correct forum for asking for help with LabVIEW Robotics.  You have already asked about this algorithm here...
http://forums.ni.com/t5/LabVIEW/robotics/m-p/2066890
If you still need help, you should continue the discussion there.
(2,709 Views)
