NI Labs Discussions
<userlib> FPGA Interface Advanced Tools cannot be found
I get the below error when trying to load a user-made library, which depends on the FPGA Advanced Tools:
loading:
<userlib>:\_FPGAInterface Advanced Tools\FPGA Interface Base\ FPGA Interface Base.lvclass
I have a mac on which I installed Windows through Bootcamp, I'm not sure if that makes a difference in the path.
I had installed the FPGA Interface Advanced Tools 2016 (and restarted my computer) from here:
https://forums.ni.com/t5/NI-Labs-Toolkits/LabVIEW-FPGA-Advanced-Session-Resources/ta-p/3500447
The installer says its installed, but I'm not sure how to check the path. Where did they get installed?
Thanks a lot,
Elena
(4,430 Views)
In case anyone is as confused as myself, finally I found these to be located here:
C:\Program Files (x86)\National Instruments\LabVIEW 2016\vi.lib\NI\LVFPGA Adv Session Resources
However - I still have the same problem - where is the FPGAInterface Advanced Tools\FPGA Interface Base\ FPGA Interface Base.lvclass
Please help 😞
Thank you
(4,378 Views)
Well, in case anyone else is having this issue.. It was solved via installing the deprecated version of the tools called FPGA Interface Advanced Tools, whereas my installed version was the FPGA Advanced Session Resources.
These versions contain completely different VI's so beware which version of the tools your library depends on.
(4,372 Views)
