NI Labs Toolkits
How to testing mobile phone parts
You can use tesile testing machine to mobile phone parts ,The Technical Parameters is
Universal Testing Machine
Capacity (optional)
50-100KN
Unit (Switchable)
G, KG,  N,  LB
Load Resolution
1/100,000
Load Accuracy
< ± 0.5%
Stroke (include the grips)
1000mm
Test speed
10~300mm/min selectable
Weight (exclude the grips)
680Kg
Operation Mode
PC
Display
PC
Motor
Servo  Motor
Dimension(W×D×H)-Main Unit
983×603×1540mm
Driver
High precise ball screw
Power
Single phase, 220V/ 10A or designated
Accessories
Tensile grips 1 set, one computer
Contributors
