NI Labs Toolkits
Mark VIs Separate Compiled Code.vi
This Tool has been superceded by theSeparate Compiled Code for VIs and Other Files tool.  Please download the new tool at the following location  https://decibel.ni.com/content/docs/DOC-20926
Comments
Craig_
NI Employee (retired)
on
If you want to see the block diagram you can press CTR + . when it loads.
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
warren_scott
Active Participant
Active Participant
on
There's a bug in this -- it does not work for files in .llb's.  The search goes through files in llb's, but the VI to read the type of the file specifically says it does NOT work for files inside .llb's.
SMcGraw
on
Thanks for letting me know about this bug.  I've updated the other tool with a fix.
Contributors
