The NI cDAQ-9191 is a 1-slot NI Compact DAQ 802.11 Wi-Fi chassis that is combined with NI C Series measurement devices for small distributed sensor measurements.
The NI cDAQ-9191 Data Display for iOS lets you visualize and save data from an NI cDAQ-9191 chassis on your iPad, iPhone, or iPod Touch with iOS 5.0 or later.
Note The NI cDAQ-9191 requires a firmware upgrade to support the NI cDAQ-9191 Data Display application. Go to NI cDAQ-9191 Firmware Upgrade for Mobile Device Support to download the firmware update. |
Configure the NI cDAQ-9191 chassis by completing the following steps:
Note A computer running Windows or Mac OS X with Microsoft Silverlight is required to complete the setup process. |
NI cDAQ-9191 Data Display is designed to run on any iPad, iPhone, or iPod Touch with iOS 5.0 or later. Download the NI cDAQ-9191 Data Display mobile application by completing the following:
Device Type | Download Link |
iPad iPhone iPod Touch |
With NI cDAQ-9191 Data Display you can perform the following tasks:
Note NI highly recommends connecting to your preferred wireless network while transmitting data with the NI cDAQ-9191 Data Display mobile application. |
After starting NI cDAQ-9191 Data Display, you are prompted to select a device. You may select a real device or simulated device. Real devices on the local subnet are automatically added to the list as they are discovered. The following options are available for choosing the appropriate device:
Note When the application relaunches, it automatically connects to the most recently used device. If the most recently used device is not present, the application may prompt you to choose a device again. |
After the device is selected, you can configure the following acquisition settings:
After the device is configured, you can acquire data in one of the following modes:
After data is acquired, you can view the data on the graph. The graph displays the most recently acquired data. You can zoom in by double tapping the graph. You can zoom out by single tapping the graph with two fingers. You can also zoom in and out by using pinch gestures. Swipe left, right, up, and down to pan the graph.
When acquiring data from multiple channels, you can temporarily hide a plot by tapping the corresponding plot legend. Tapping the plot legend again will show the plot.
To view a given plot value on the graph, tap and hold a plot to display the current X and Y value. Move your finger along the graph to update the current values.
After data is acquired, you can share the data using email by completing the following steps:
After upgrading the firmware on your NI cDAQ-9191 you can also build custom applications that interact with an NI cDAQ-9191 through a Web API.
Please use the NI cDAQ-9191 Mobile Device Feedback and Support Discussion Thread to post any questions, comments, bug reports, or other relevant information.
Licensing information for the NI cDAQ-9191 Data Display is available through the NI cDAQ-9191 Data Display for iOS Application Notices page.
For patents covering the National Instruments products/technology, refer to the National Instruments Patent Notice at ni.com/patents.
DOCUMENTATION NOTICE FOR THE BSD LICENSE
This product includes code from ASI HTTP Request, licensed by a third party or parties pursuant to the BSD License, and that is subject to the following notice(s):
Copyright © 2007-2011, All-Seeing Interactive
All rights reserved.
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this list of conditions and the following disclaimer in the documentation and/or other materials provided with the distribution.
* Neither the name of the All-Seeing Interactive nor the names of its contributors may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY All-Seeing Interactive ''AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL All-Seeing Interactive BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This product includes code from Reachability, licensed by a third party or parties pursuant to the BSD License, and that is subject to the following notice(s):
Significant additions made by Andrew W. Donoho, August 11, 2009. This is a derived work of Apple's Reachability v2.0 class.
Extensions Copyright © 2009 Donoho Design Group, LLC. All Rights Reserved.
* Neither the name of Andrew W. Donoho nor Donoho Design Group, L.L.C. may be used to endorse or promote products derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY DONOHO DESIGN GROUP, L.L.C. "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This product includes code from Dejal Activity View, licensed by a third party or parties pursuant to the BSD License, and that is subject to the following notice(s):
Copyright © 2002-2012 Dejal Systems, LLC. All rights reserved.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
DOCUMENTATION NOTICE FOR PROPRIETARY APPLE LICENSE
This product includes code from Scroll View Suite, licensed by a third party or parties pursuant to a proprietary Apple license, and that is subject to the following notice(s):
Disclaimer: IMPORTANT: This Apple software is supplied to you by Apple Inc. ("Apple") in consideration of your agreement to the following terms, and your use, installation, modification or redistribution of this Apple software constitutes acceptance of these terms. If you do not agree with these terms, please do not use, install, modify or redistribute this Apple software.
In consideration of your agreement to abide by the following terms, and subject to these terms, Apple grants you a personal, non-exclusive license, under Apple's copyrights in this original Apple software (the "Apple Software"), to use, reproduce, modify and redistribute the Apple Software, with or without modifications, in source and/or binary forms; provided that if you redistribute the Apple Software in its entirety and without modifications, you must retain this notice and the following text and disclaimers in all such redistributions of the Apple Software. Neither the name, trademarks, service marks or logos of Apple Inc. may be used to endorse or promote products derived from the Apple Software without specific prior written permission from Apple. Except as expressly stated in this notice, no other rights or licenses, express or implied, are granted by Apple herein, including but not limited to any patent rights that may be infringed by your derivative works or by other works in which the Apple Software may be incorporated.
The Apple Software is provided by Apple on an "AS IS" basis. APPLE MAKES NO WARRANTIES, EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION THE IMPLIED WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE, REGARDING THE APPLE SOFTWARE OR ITS USE AND OPERATION ALONE OR IN COMBINATION WITH YOUR PRODUCTS.
IN NO EVENT SHALL APPLE BE LIABLE FOR ANY SPECIAL, INDIRECT, INCIDENTAL OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) ARISING IN ANY WAY OUT OF THE USE, REPRODUCTION, MODIFICATION AND/OR DISTRIBUTION OF THE APPLE SOFTWARE, HOWEVER CAUSED AND WHETHER UNDER THEORY OF CONTRACT, TORT (INCLUDING NEGLIGENCE), STRICT LIABILITY OR OTHERWISE, EVEN IF APPLE HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Copyright © 2010 Apple Inc. All Rights Reserved.
