NI Linux Real-Time Discussions
Building IPK on PXI with Linux RT
Thinking I might be invoking opkg install incorrectly using the entire filename I tried just
opkg install hellopkg and got the following:
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
Message 11 of 25
(1,911 Views)
Thanks for sending that information and your ipk. This behavior is very strange and I can't even get it to reproduce.
FYI, the second error is reasonably expected. opkg is trying to use the "hellopkg" directory instead of the ipk when you run the command (as there's no hellopkg ipk since the system isn't accessing our repos) and fails accordingly.
I've tried installing the xinetd-dev ipk after downloading it, and I get the expected errors on an offline system (missing dependencies). After that, I have no issue installing your ipk. At least there's the good news that your ipk works on my system without issue!
  1. Can you try running opkg update and the installing?
  2. Is there anything in the /var/cache/opkg directory? This should be cleared after each ipk installation. If there's something there, try removing it.
  3. If all that fails, try running opkg with an increased verbosity level for debugging purposes. E.g., opkg -V3 install <package name>. I'd recommend routing the output of that to a log file so you can see if anything stands out.
Charlie J.
Message 12 of 25
(1,907 Views)
This is an offline system and I can not run opkg update with it - it is not allowed to be connected to the internet for govt security issues.
I will check and see if there is anything /var/cache/opkg
I'm glad to hear that my little helloworld ipk installs properly, that's good to know.
So when I run the opkg install its proper form to use the whole filename with .ipk, such that opkg install hellopkg_1.0.0_x64.ipk is valid?
Message 13 of 25
(1,901 Views)
There is nothing in /var/cache/opkg
Message 14 of 25
(1,896 Views)
Looking at the information from v4 verbosity, I think installing the ipk wants to download from the online repo?  This is of course going to fail, since the system is offline.
I copied the last line into the file as that wasn't added in when I piped the install outputs to the text file.
Message 15 of 25
(1,877 Views)
Can you try running the install for your hellopkg with the same logging? We know the xinet should fail since it's missing dependencies, but your package shouldn't have that issue.
Charlie J.
Message 16 of 25
(1,871 Views)
here are three levels of verbosity for the install of the hellopgk_1.0.0.0_x64.ipk
Still getting the odd response from asking to install hellopgk that is referring back to xinetd - something is "stuck" somewhere it seems in the opkg side
Collected errors:
* Solver encountered 2 problem(s):
* Problem 1/2:
* - nothing provides xinetd = 2.3.15-r2.154 needed by xinetd-dev-2.3.15-r2.154.core2-64
* Solution 1:
* - do not ask to install xinetd-dev-2.3.15-r2.154.core2-64
* Problem 2/2:
* - nothing provides libc needed by xinetd-2.3.15-5.x86_64
* Solution 1:
* - do not ask to install a package providing xinetd
Message 17 of 25
(1,866 Views)
That's weird. It recognizes that you're installing the hellopkg but xinetd-dev is still marked for install. I'm actually not entirely sure how that happens.
Let's see if we can trick opkg into installing xinetd-dev and then remove it. Specifically use the following flag when installing the package to tell it to proceed without dependencies:
--force-depends
Afterwards, try removing xinetd-dev with the same flag, then install your package.
Charlie J.
Message 18 of 25
(1,860 Views)
It didn't like that either - still failed saying it could not download xinetd
Collected Errors
* opkg_download_file: ///etc/opt/repo/19.07/x86_64/packages/xinetd_2.3.15-5_x86_64.ipk: No such file.
* opkg_install_pkg: Failed to download xinetd. Perhaps you need to run 'opkg update'?
Maybe I should download xinetd_2.3.15-5_x86_64.ipk from the feed manually and install put it in the expected location and try that again...
Message 19 of 25
(1,855 Views)
ok I downloaded xinetd_2.3.15-5_86_64.ipk
tried install
requested /etc/opt/ni/2091.1/initscripts-dev_1.0-r155.44_core2-64.ipk
I downloaded that and then installed xinetd_2.3.15-5_x86_64.ipk
opkg info xinetd seems to show xinetd_2.3.15-5 installed
Went back and tried opkg install hellopkg_1.0.0_x64.ipk and this time got a different error:
Collected Errors:
Solver encountered 1 problem(s):
* Nothing provides requested initscripts-dev
performed opkg info initscripts-dev
and it is indeed not installed - says the file I need
Filename: initscripts-dev_1.0-r155.44_core2-64.ipk
I will try to download that...
Message 20 of 25
(1,851 Views)
