NI Linux Real-Time Discussions
Cannot ssh to cRIO
I use Ecplise to ssh to my cRIO 9068 using the remote system explorer. (SSH Terminals)
Today I used OPKG and used the "opkg update" and "opkg upgrade".
I ended the ssh session.
When I wanted to re-launch the ssh terminal a dialog appeared: "Keyboard Interative Authentication for username@host" requesting a password.
If i use the same password as previous it does not work and after a few attempts: "SSH_MSG_DISCONNECT: 2 Too many authentication failures for username"
I tried to ssh using putty but the behaviour is the same.
By using the same user and pass I can succesfully login into MAX and also in the NI Web Base Configuration and Monitoring.
What is going on ?
Anyone else with this problem ?
Robert.
(5,199 Views)
Hi Robert,
There is a currently an issue with doing 'opkg upgrade' on our current software repositories.  We're working on a fix for this, but currently we recommend avoiding doing an 'opkg upgrade' operation.  You should still be able to install and/or upgrade individual software packages, you just need to avoid upgrading *all* packages.
To get your 9068 back to a working condition you can re-format your target through MAX.
(4,770 Views)
Thanks for the reply, everything works fine now after formatting.
(4,770 Views)
